vcMaterialInheritance
Parent: Enum
Referenced by: vcNode.MaterialInheritance
How to access:
import vcCore as vc
vc.vcMaterialInheritance.<ENUM_VALUE> # replace <ENUM_VALUE> with the desired enum value
Enums
ValueDescription
DISABLEDSetting does not affect the stack at all.
FORCESetting overrides INHERIT for the current geometry set.
FORCE_INHERITAs INHERIT, except it also overrides FORCE materials.
FORCE_INHERIT_LEVELAs FORCE_INHERIT, except only for the current group of DSG nodes.
FORCE_INHERIT_NODEAs FORCE_INHERIT, except only for the current DSG node.
INHERIT
Setting specifies a material for the entire node subtree that overrides any SET materials.
INHERIT_LEVELAs INHERIT, except only for the current group of DSG nodes.
INHERIT_NODEAs INHERIT, except only for the current DSG node.
SET
Setting is used on the current geometry set only. This is overridden by INHERIT.
